Home > In Car Electronics (L322) > Cubby box 12v socket
J90
France 2006 Range Rover Vogue Td6 Java Black
The 12v socket in my cubby box only works with the ignition on. I was under the impression that it was always supposed to be live. If that is correct what fuse should I check or replace to make it 'live' again?
Thank you. Travelling around in circles again.
Post #312887 15th Feb 2015 7:54pm
you cant make it permanent unless you re-wire it....the boot one is permanent live and you could run a feed to the front.. ... - .- -.
Post #312897 15th Feb 2015 8:14pm
Discotigger
The 12v sockets run through relays, that's why they normally only become live when the ignition is on.
It is possible to make them permanently live, by removing the relay and using a bridge across the terminals. It's been done in my 2005 FF the relays have been removed and bridging contacts put across the terminals to make all my 12v sockets permanently live, but don't know if it is a standard thing done, or just a 'fix up' by one of the previous owners.
Post #312900 15th Feb 2015 8:16pm
J90
Thanks for the swift replies guys. I'll have a think about running a feed from the boot socket to the cubby box one. Travelling around in circles again.
Post #312901 15th Feb 2015 8:20pm
It's a lot easier to do what Discotigger suggests than running a new cable.
You simply need to remove the relay serving the accessory socket on the rear fuseboard, fit 100mm of cable with a male spade connector on each end and push the spade connectors into the respective holes in place of the relay.
Post #312903 15th Feb 2015 8:34pm
Discotigger
Exactly nicedayforit Thumbs Up
The fuseboard in the rear right hand boot cubby has the relays for the accessory sockets. The relay that controls my accessory sockets has been removed and a metal bridge has been inserted that ensures my 12v sockets are permanently live.
Simple fix. Thumbs Up
Post #312906 15th Feb 2015 8:46pm
mjdronfield
My cubby box one is always live. Must have changed on the later cars......
Unless mine has been modded...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #312908 15th Feb 2015 8:49pm
^ The wiring diagrams show two options, ignition controlled and not.
Irrespective of the model / year of the car some have one option some the other.
It doesn't seem to be consistent one way or the other, I get the impression it depends on who's fitting them on any particular day. Whistle
Post #312911 15th Feb 2015 9:03pm
Discotigger
The easy way to find out is to look at the relay panel in the rear right hand cubby box. If there is a relay missing from the board and a metal bridge strap in its place, then the 12v accessory sockets will be permanently live.
Post #312914 15th Feb 2015 9:15pm
J90
I think the 100mm of cable as suggested by nicedayforit is the way to go. Ta Travelling around in circles again.
Post #312916 15th Feb 2015 9:41pm
Just a point about the cable, as the circuit is fused at 20A the cable also needs to be rated at 20A. Thumbs Up
When you remove the relay you will see the terminals on it numbered on the pin side.
You need to look for the pins 30 and 87 and put the cable spade connectors in the corresponding holes in the fuseboard.
Post #312919 15th Feb 2015 9:48pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
My 03 TD6 was always live, this 06 SC is not. It seems that it changed when it went from BMW to Ford under the skin.... 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #312923 15th Feb 2015 10:26pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Any pics of the relay you need to bypass? _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #318246 16th Mar 2015 11:44am
