|  | Home > Maintenance & Mods (L322) > Removable Towbar |
| jeffw Member Since: 18 Jan 2015 Location: Paddock Wood Posts: 60      | No ideas guys? 2011 4.4 TDv8 Vogue SE
|  16th Feb 2015 6:13pm |
| RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187      | Hi
|  16th Feb 2015 6:51pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    |
 worth using the search function, came up with these, http://www.fullfatrr.com/forum/search.php?...rch_time=0 ... - .- -. Y. O. L. O. . | ||
|  16th Feb 2015 7:03pm |
| SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110      | Mine was same. Copious amounts of WD40 and hammering solved the problem. | ||
|  16th Feb 2015 8:17pm |
| Elduke Member Since: 21 Apr 2013 Location: Glasgow Posts: 148      | You could try taking a file to the v recess on the receiver and on the opposite part on the tow hook. I had the same myself and the big hammer did not work. Surprisingly tight tolerances between it locking out and not obviously a bit of surface corrosion stopped it. | ||
|  16th Feb 2015 8:18pm |
| jeffw Member Since: 18 Jan 2015 Location: Paddock Wood Posts: 60      | Thanks for the responses...
|  16th Feb 2015 8:35pm |
| jeffw Member Since: 18 Jan 2015 Location: Paddock Wood Posts: 60      | Hitting the underneath of the removable hook with a lump hammer has cured the issue.  Now fits and removed correctly.
|  18th Feb 2015 6:50am |
| AxxA Member Since: 17 May 2020 Location: South Posts: 11      | Recently got the problem with mine, hammered the thing, OK. Used my trailer, etc. Upon to remove the hook.. no way. It was stuck inside the arm!
|  30th Jul 2020 8:22pm |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | Looks like you've grounded the hitch?? You could have caused a burr where the pin should protrude? | ||
|  31st Jul 2020 10:21am |
| AxxA Member Since: 17 May 2020 Location: South Posts: 11      | Yes, the hitch had been used as a plow lol. Rangie had broken its serpentine belt, so had to be towed and it was in normal suspension mode, but as it has some heavy load in the boot (tiles) it went down on the rear suspension... so when gettin up and down of the tug the hitch plowed the ground.
|  31st Jul 2020 10:38am |
| Posting Rules
