![]() | Home > Technical (L322) > Engine cranking not starting |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
^ Alternator |
| William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 154
You really think alternator gazellio?? Do they go wrong much? And how to i correctly tell it's the alternator? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834
14.1 volts is ok, anything between 14 and 14.5 is acceptable.. ... - .- -.
Hmmm looks like I'm in abit of a pickle lol. It must be something electrical as for the cut out from cold it took 1hr while on idle to cut out then about 15mins worth of driving it cut out. But when it did cut out I tested it and only 11.75 volt so perhaps faulty alternator or the cabling I hope. Any other thoughts?? |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983
I presume your battery terminals are tight?
Well we have another problem now. Put the battery on charge got 100% put it back into the car and now the car cracks for 5 seconds and stops completely!!! Repeat it again does the same thing cranks for 5seconds then stops!!! |
For people that want to know I've replaced the regulator and all seems fine phew...now just gotta get the sat nav working |
