![]() | Home > Maintenance & Mods (L322) > IID BT options |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
So my IID BT tool arrived this morning (but not home yet to try it out)
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
when the Craig-meister came round to show off his new FF, he showed me the kph/mph switch over which was done via the iidtool.....hopefully he will expand on the 'goodies' that can be done when he sees this thread. ... - .- -.
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Hmmmm! This could help as been thinking if buying one myself and looked at an online manual but it doesn't seem to list many of the options I've heard that it can do
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Have a look here
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Stan, i have a Beta testing IID Pro tool which i believe cannot be purchased yet and has more/other options to the normal BT unit... Therefore wouldn't like to list what mine can do incase it/they are not available on the ordinary BT unit ![]() ![]() |
Craig, the pro version is available now from Dan at Duckworth parts for £1850 Inc vat. Your version may have testing of modules and things before being transferred as an update to the consumer version. |
Can it put my TD6 into quiet/powerful mode? |
It can David yes |
Sound good - Can it make my 3.6 into a 4.4 with some "Special" setting..?
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
I added the digital speedo to my dash - not sure about Up There but Down Under we didnt get that option standard. 2017 Range Rover Vogue SE SDV8 (with e-diff)
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
For that, you need the BAS interface instead ![]() |
