![]() | Home > Technical (L322) > New Windscreen Fitted - Auto Wiper Problem |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
OK, brand new LR sensor has just been fitted and the lights and wipers STILL don't |
in all the hassle you've been having i wonder if the connections have come loose somewhere, other than that , check fuses and a battery reset... ... - .- -.
I cannot get anyone to 'admit' to cutting any wiring, so can only assume they've not.
Final update here.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Glad its finally sorted sir |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
I had this too...also with National Windscreens.
The irony to all this is I noticed a tiny flaw in the Pilkington 'screen last night on the way home. It's about 1" diameter and on the lower passenger side. The flaw gives a small 's-shaped kink to things in that area.
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 456 ![]() ![]() ![]() |
I had screen replaced about 6 months ago by Autoglass, first fitter on site was very good and careful then a monkey turned up to help him take the old screen out.
Glad it's sorted Si,
Ryan, I think we both arrived at the same conclusion.
Thanks Si, it LR and also Pilkington stamped as ours just says Pilkington?
Just Pilkington.
its uncanny that you and Ryan have the same model and colour and both suffer with 'unusual' problems..
