![]() | Home > Technical (L322) > Iid Bt tool |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Take a look at GAPs website, all the options that can be changed are there.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
i've ,
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
@Stan - Where did you find the volume control for the PDC..?
PAM-parking aid menu Ash... ... - .- -.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
I'm not a lard arse and can get in and out with having the steering column doing it's retracting act so i'veswitched off the retractable steering column as i've seen a few posts where the column has got stuck, meaning the car isn't driveable.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7988 ![]() ![]() ![]() |
Enabled park heat, so I can set the FBH to come on in the morning. Have Aux Heat / Vent on the menu now
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
That'll be the kiddie then Evro
Mines an early car, so the fbh system may be slightly different activation wise..... 2011 Range Rover Vogue SE 4.4 TDV8
@Ash, is it in the FF's dash menu perhaps.. ... - .- -.
Thx Stan - will have another look
RTFM |
Not if you also do the dash reset - it appears straight away then (or did on mine) I was also advised of this by my local LR indy Ash
