![]() | Home > Technical (L322) > Brakelights/Switch. L332 TD6 |
I don't know about your brake switch but the air suspension inactive / hdc / abs lights on usually indicates a low voltage occurrence. Hows your battery? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Brake light faults on the early cars is usually down to a failing LCM... |
Have you fitted any LED's to the vehicle? Land Rover Addict
Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34 ![]() ![]() ![]() |
Hi thanks for your reply,Yes the rearlights are Led;s |
Thanks will check Battery |
If you have an IID, switch off cold/hot monitoring and it should stop the flash (that's the car checking the lamps if they are filament)
Cool Thankyou |
Yes they do! Very common LCM's failing and leaving the brake lights permanently on!!! |
Hi checked multiplugs sensors all ok. went to LR specialist only thing that came up was Brakelight switich. The new one I fitted was from LR Direct a Brtipart switch. Specialist said get a Genuine one and try that. Done this today and the brakelights stayed on permanently ?? |
Behind the bonnet pull panel... Black box |
Cool thankyou. Hope this is what it is. Coz Im pulling my Hair out |
Evening well Changed LCM fitted new genuine brakelight switch cleared the codes. Hey Presto |
Somewhere in my memory bank i remember there being an issue with a loom between the abs ecu and either the lcm or the bcm and JLR suggest you cut a wire from the abs ecu...
