![]() | Home > Technical (L322) > First gear whirring / whining noise |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8781 ![]() ![]() ![]() |
Never read about one whining, hopefully Phil will read this as he's the man who will know...
Blubberman Member Since: 11 Nov 2010 Location: South Wales Posts: 39 ![]() ![]() ![]() |
Cheers Pete, thank you for the suggestion
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Strange it only happens in first, from what I can recall I don't think there would be many bearings specific to first, and as such you would think it would happen in more than one gear.
Yes it is a strange one, and to be honest most of the problems I have had with the Rangie over my 5 years of ownership I can find the answer to the problem by doing a search on FFRR or by googling other forums , ( that is why I don't post on here very often ) , but despite searching various forums and doing google searches I can find nobody else who has had this problem before.
You can't measure it anywhere near correctly with a gauge, the oil temp sensor is deep in the gearbox and the difference between the sump and the sensor will be massive, it is designed to be filled at a temp the sensor measures, you need an IID tool or something similar to measure it.
An update on the problem .
Craig (Cam Tech Craig) recently posted a warning on diff oil changes being needed regularly based on some issues he noticed with client cars, it sounds like yours also urgently needs the diff oils to be changed ! MY 2010 5.0 SC Galway green and sand interior!!
I did the rear one last year, but to be honest there was not much point because the oil that came out was spotless. I bought the oil to do the front one at the same time but never got round to it . Going to do the front one this week . Its big , its black and we call it THE BEAST ! |
Mate, I know what you mean and it happens to me a lot as well. Get the parts and then all kinds of other things happen in getting the work done |
