![]() | Home > Technical (L322) > Dreaded Flat Battery |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
I think there's a good chance you may have found the problem. |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Same happened to my 12S. Wondered why the fuse kept blowing? Fitted new one (from Halfords) & changed over cover to keep LR logo (PITA). Previous cars:
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
Well, went to come home from work and the |
Well I left it overnight then got the jump leads on it. At first it wouldn't start though the voltmeter was reading 13.5v but after a couple of minutes it fired up.
Iirc the boot wiring wouldn't be up to the job to provide cranking power for the starter.
Testing CCA isn't always a reliable test from what I can see unless you repeat the test a lot of times to get a good average or just fully change it off the vehicle and compare to another one that's brand new...
Do you have a voltmeter you could connect permanently inside the car so you could check the voltage whilst you are driving? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Can do that via the hidden menu on the sat Nav screen |
Well there you go |
Mine goes high as it puts the voltage back used to start the car, then settles around 13.5-14v the built in volt meter only steps in .5v so I'm assuming that's 13.8v which is bang on. |
Given the inbuilt voltmeter reads on 0.5V steps I'd be inclined initially to use a possibly more accurate voltmeter initially.
I have one of those that plugs into the 12v socket that someone here recommended. All readings are as expected. I now have it plugged in the boot socket with the display on the parcel shelf so I can see it without opening the car.
In my experience the only good cars to jump off are 2.0diesels as I've tried before with a 1.6 golf and it took a few minutes more to get enough juice in compared to a 2.0 gtd and some 2.0 Citroens I've had around |
12.2V is low if it stood all night prior to starting.
