![]() | Home > Technical (L322) > Clunky changedown after full service (inc gearbox service). |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 124 ![]() ![]() ![]() |
My 07 TDV8 with 230,000 ks grarbox oil was changed 3000ks ago, and I do have this 2-1 harsh change down on occasions. Is there anything I can do. I don't believe my adaptive values were reset, and from memory I had a hard change going up in gear before occassionaly. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
There is a gearbox software update which can be done, it can help slightly, mine was slightly better after. There is nothing that can't be fixed with a hammer😜😜
Software up date for the gear box is LandRover Technical Bulletin = LTB00267 2008 MY Supercharged
francy Member Since: 30 Jul 2012 Location: northwest Posts: 83 ![]() ![]() ![]() |
hello had gearbox service on my td6 no updates all good |
Update is for the 6hp26 on the tdv8. |
Rovertech Member Since: 25 Feb 2015 Location: Seattle Posts: 20 ![]() ![]() |
Actually, ZF prohibits erasing adaptions unless specifically authorized by a ZF engineer. I'm a dealer tech, have changed the fluid in hundreds of ZF trans, and have never reset adaptions. To answer the OP, there is a bulletin for TCM software updates depending on model year, also if this was a quick lube kind of place, they probably under filled the trans. I would check the fluid level. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1530 ![]() ![]() |
God, you know something the more topics on this, the more I'm confused. I think I'll just leave it until it goes bang and set fire to the car and walk away.
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 ![]() ![]() |
Thanks for all the replies, everyone. My car is 06 4.2SC. I will get the fluid level checked. On my invoice: Gearbox Filter Screen = £67.00 + VAT. ATF Oil - 8 litres = £50.40 + VAT. Labour = £78.75 + VAT. I have only just realised that the gearbox service cost me £235.38 including VAT. ![]() Took the car out this morning and can't say I really noticed the 2-1 change down as much. ![]() |
Hi mate, it is quite important that you do put original Lifeguard 6 in the box. Normal ATF shouldn't cause the issue of the clunk but still.
Just read Rovertechs advice, I suggest to go with that but make sure it is Lifeguard 6 in there and nothing else. MY 2010 5.0 SC Galway green and sand interior!!
No Arcle that is NOT expensive at all sir... The oil should be considerably more (£££) than that! So far reading your posts here i would seriously consider where you take your car from here on sir ![]() No reset on service ind ![]() Tech not having the ability to rectify the service reset! ![]() Gearbox fluid change woe's ![]() (Maybe) low on gearbox oil ![]() (Maybe) now appears the wrong fluid used in gearbox! ![]() ![]() ![]() I would have the car somewhere else quick smart to check the whole job through! Your engine needs a particular grade & quality of oil too sir... |
Thanks for all the help, everyone.
I have PM'd you sir... |
