Home > Technical (L322) > Blindspot mirror
Page 2 of 3 <123>
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
No, you can just register as an independent. You get access to some basic info about your car (build specs etc) plus owners manuals. Like everything in life though, you pay for the good stuff (bulletins and repair info etc). You can pay by the hour though which isn't too terrible. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #314568 24th Feb 2015 9:41am
free to register, free to look at the owners manual and fitting guides but you need a subscription to view or download any thing else.. ... - .- -.
Post #314569 24th Feb 2015 9:43am
Rovertech
United States
Blind spot monitoring uses two small sensors in the rear bumper, not the cameras, although that would probably be more
Reliable. If you have the below icon in your mirror then the vehicle should be equipped, and the selection with be under the vehicle set up option on the TFT. If there's a YELLOW DOT ONLY, then you either haven't reached the required speed, or your
System is faulty.
Post #314978 26th Feb 2015 3:24pm
hoppy_70
I definitely have the mirror fitted with the LEDs. It also appears to be wired up, but It isn't anywhere in the menus that I can see and has never lit up Rolling Eyes My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #315012 26th Feb 2015 7:33pm
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Emirates777 wrote:
Cam-Tech-Craig wrote:
Does yours have vision assist pack? (camera's)
happy_70
You should have this on the LCD dash if its fitted - have a look
Ours are lit up green on both cars when engine is running.
again hope this is of help to you.
Ooh..best I go and take a look and see if I have this Whistle Thumbs Up
Post #315135 27th Feb 2015 11:05am
Yes you will have it Whistle Whistle Whistle Rolling Eyes
Post #315142 27th Feb 2015 11:24am
devonchilliman
Well...yes I have Mr. Green ...everyday is a schoolday Thumbs Up ,this car just keeps giving Bow down
Post #315262 27th Feb 2015 6:29pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
BSM- some door mirrors have the symbols but system is not connected.
BSM works two ways, one it picks up vehicle in BS and you get a light on in the mirror in, two - if the vehicle behind is closing speed >25% than yours it will light up 75m behind you and you will get an additional audibale wng when the vehicle goes into your blind spot. Cheers
James
Post #315284 27th Feb 2015 7:53pm
JST
sorry - forgot to add, just becuase you haev fwd alert doesnt mean you will have BSM. Cheers
James
Post #315285 27th Feb 2015 7:54pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Indeed - I have forward alert but no LEDs or anything in the wind mirrors. Also nothing shows on the tat screen to activate it.
I'm guessing it was not installed on mine Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #315327 27th Feb 2015 10:35pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Quote:
"Rovertech"]Blind spot monitoring uses two small sensors in the rear bumper, not the cameras
wrong
The BSM devices are in the rear quarter panels on each side just front of the rear lights. The workshop manual clearly show their location. If you look you will see that these quarter panels are made of plastic - as this does not interfere with the radio/micro sonic waves that the system is sending out motoring whats around.
Both our L322 have plastic quarter panels - they are not alloy as I have tested with magnet.
The square BSM system units can be clearly been seen when you take the inside carpet panels off. There is also a audio speaker system fitted on each side - I guess this is that makes the sound when something is getting near your ass - its time to put metal to the floor when they bleep
hope this helps again[/quote]
Post #315565 1st Mar 2015 2:01pm
EmiratesA380
Quote:
BSM works two ways, one it picks up vehicle in BS and you get a light on in the mirror in, two - if the vehicle behind is closing speed >25% than yours it will light up 75m behind you and you will get an additional audible warning when the vehicle goes into your blind spot.
Hi JST
Have you tried or come across this:
- I had this the other day on route to the airport - some Muppet decided to stop when turning off a bit sharpish - the Warnings came up on the dash board with the bleeps ( Ive got is set on Max scanning range ) - I noticed the brakes were being applied for me and the brake pedal was jerking under my foot when I applied the brakes - the same as you get when the ABS system is being activated very very hard.
Is this another device when you are braking at the last minute to let you know the brakes are being applied ( as well as you ) - has anyone else encountered this - although I would not want to leave ALL THE BRAKING to all the car itself just incase it did not stop in time.
Post #315570 1st Mar 2015 2:57pm
JST
what you are describing is part of the fwd alert system working in conjunction with emergency brake assist (EBA).
EBA precharges the brake system so a light touch will act as an emergency stop.
EBA also takes into account the rate at which the brake pedal is pressed which is something most EBA car systems from other manu dont do. most (including JLR) work on time difference between coming off the acc pedal and hitting the brake pedal.
going back to fwd alert picking up an obstruction - if you dont brake and the vehicle thinks an impact is immenant it will brake itself to reduce the speed of the impact - it will not brake you to avoid the collision unless you have queue assist.
if you have queue assist it will stop the vehicle. if you dont have queue assist fwd alert wont stop the vehicle (it works the same as in ACC) it will brake you to 20mph thats it.
in essence EBA and Fwd Alert have been around ages, queue assist package has only recently been added as software development allowed it. Cheers
James
Post #315627 1st Mar 2015 8:46pm
somchie
Sweden
I'm probably not helping Smile
But...
I have BSM on my S/C and it's working, I don't however have that "22"-symbol showing up and I don't have the LED dot when standing still. (I do however have that on my Sport) Range Rover SV Autobiography LWB 5.0 S/C -17
Aston Martin Rapide S -17
Range Rover Sport SDV6 Autobiography Dynamic -14
previous: Range Rover 5.0 Supercharged -10, Land Rover Defender 110 SW LXV -14, Discovery 4 HSE -11
Post #315689 2nd Mar 2015 3:00pm
Andy B
Hi Somchie,
For "22" you have to switch on 'Forward Alert' via the TFT menu. You then get the green triangle.
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #315713 2nd Mar 2015 5:10pm
Page 2 of 3 <123>
