![]() | Home > Maintenance & Mods (L322) > 4.2SC - New Oil Filter Housing Assembly needed. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
makes sense now ryan, it does look like a very fiddly job though.. ... - .- -.
I think the part leaking and which the new figure 8 O-ring gasket seal is for is called the Oil Filter Housing.
This is an LR warrantied repair.
ryan@ landrover relations might be able to help.. ... - .- -.
Cheers Stan. Seems little point. If I persist with the garage they will book it in.
that makes sense, hope your new chap sorts it for you.. |
If a new LR part/ figure of 8 oil filter gasket seal was fitted then oil still weeping from the figure 8 component mating face, what could be the issue?
I can think of several potential problems :
Thanks Eugene,
No worries mate. Without seeing the actual part up close it is the best I can do, just based on years of tinkering with cars, hydraulics and the likes.
Based on some online research it seems the oil filter housing can be a common oil leak component on the RR?
was the oil seal put in upside down perhaps? ... - .- -.
Worth checking Stan, thanks |
Well, had good look at this problem now.
