Home > Technical (L322) > Fuel Gauge playing up
supershuttle
I have got used to the speed of downward movement on the 5L Supercharged but this morning the gauge twice just went from 3/4 full to 1/4 full of its own accord with a corresponding drop in distance to empty of 230 miles to 89 miles.
It seems OK now - has anyone else experienced this ? Geoff
Post #314482 23rd Feb 2015 2:39pm
When mine did it albeit on a 2008my it was the in tank senders. Used to flick between full and empty but only when I had brimmed it. New sender sorted it. There is nothing that can't be fixed with a hammer😜😜
Post #314519 23rd Feb 2015 8:19pm
Rovertech
United States
Typically senders on that, you can check them yourself from the out of tank connector multi plug with an ohm meter to determine which is faulty, but I always replace both.
Post #314776 25th Feb 2015 3:29pm
Zain
Whats the approx total cost to replace both senders - my gauge is just continuously erratic.
Post #314864 25th Feb 2015 10:18pm
Not cheap,
From memory the senders were about £250, plus fitting which was about 1.5hours I think. There is nothing that can't be fixed with a hammer😜😜
Post #314865 25th Feb 2015 10:22pm
Re: Fuel Gauge playing up
Geoff, its a well known fault and there is a TSB about it sir... Recommended (by JLR) the dealer has your car removed the tank pump plug (internally) and solders the wiring together as the wiring plug goes wrong! Even fitting a new pump will not fix the fault long term sir...
Fault is because "one pump" stops reading fuel level and a mean average is then taken so will always read 1/4 full Thumbs Up
Post #314898 26th Feb 2015 12:36am
supershuttle
Craig, I take it that I will have to pay for the work or is it warranty? Geoff
Post #314902 26th Feb 2015 1:05am
Try your dealer Geoff... Unsure weather its a non cost repair sir (i would guess probably not!) Rolling Eyes
Post #314908 26th Feb 2015 2:19am
Rovertech
United States
Unnecessary quote removed
That TSB is garbage. Not too many of us actually believe in it. And we're simply putting a PIDGE connector on the two wire connectors, not actually soldering them. If it's under warranty we have to do this first, but I've had this bulletin fail on 3 occasions, and I end up doing senders anyway.
Post #314975 26th Feb 2015 3:01pm
supershuttle
Is this a DIY job, can the bridging be done externally?
Its actually stopped playing up at the moment but I'm sure it will recur. Geoff
Post #316027 3rd Mar 2015 10:12pm
And on how many occasions have the fix worked?
I have done this 20+ times and its not failed to work yet!
So, please don't be so quick to dismiss something as "GARBAGE" on an open public forum when clearly the TSB is there for a reason! and has clearly worked for me several times! Thumbs Up
Post #316033 3rd Mar 2015 11:06pm
supershuttle
Craig, I'm liking the possibility that I don't need to replace the senders, can it be done externally or will I have to get the tank out in which case it's probably best left to a dealer. Geoff
Post #316047 4th Mar 2015 12:11am
Geoff,
It would mean taking the pumps out of the tank (under the back seat) and soldering the connector... Thumbs Up
Post #316084 4th Mar 2015 10:01am
supershuttle
Thanks Craig.
I'll have a look at doing it myself - after all what can go wrong its only petrol Very Happy Geoff
Post #316101 4th Mar 2015 10:32am
Exactly!!!
I have ONLY ever done them on derv and have never had one fail to work... I will find you the info you need and if needs be copy it and forward it to you via e-mail...
PM me your e-mail address Thumbs Up
Post #316105 4th Mar 2015 10:38am
