Home > Maintenance & Mods (L322) > Possible engine leak on 4.4 v8
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
So I've had my FF a few months now, I've noticed a slight drip that seems to form near the front of the car so engine area along a steel bar that seems to run in parallel with the front axle.
I've opened the bonnet and can't see anything obvious so may end up taking it in to an independent but I'm just wondering what if any things are likely to leak on these BMW 4.4 v8 engines?
Having never owned a FF or even a RR before, I am unsure if this is typical or not.
I can well imagine the labour involved in changing seals is going to be high Smile
The engine has covered 103,955 miles.
Post #310780 5th Feb 2015 10:12am
ebajema
Is it coolant or oil ???? I remember that the water pumps on the BMW V8 engine had some reliability issues. If it is oil, crankseal behind the pulley or oil cooler connection/hose ?????? MY 2010 5.0 SC Galway green and sand interior!!
Post #310782 5th Feb 2015 10:14am
Alternators like to become incontinent on the BMW 4.4's if i remember correctly too Rolling Eyes
Post #310787 5th Feb 2015 10:25am
scwilson
I think it's oil, it's light in colour possibly due to it having a major service in December. When I took it in for a full service I asked them to check underneath for leaks and they said it was all fine, they said it had had new breather pipes fitted 18 months or so ago and it could possibly be excess from the old pipes that was not cleaned down.
I know nothing of these engines and I assumed if something needed doing they would have said so but I do think I have a leak somewhere.
Post #310791 5th Feb 2015 10:31am
Maybe they misheard you sir?
"When I took it in for a full service I asked them to check underneath for leaks"
Maybe they thought you required one? Well, it has got a green oval Whistle Rolling Eyes
Laughing Laughing Laughing Thumbs Up
Post #310793 5th Feb 2015 10:34am
scwilson
Apart from this, the only thing that has leaked badly is my wallet.
Post #310810 5th Feb 2015 11:12am
scwilson
In this highly detailed technical drawing, taken from underneath the car looking towards the front, the red arrows indicate where a drip sometimes forms on the bar(s) and the red circle is where I think might be wet, but difficult to tell.
Over two months I have had a few drips on the drive but I would obviously like to narrow down where it is coming from.
Post #310969 5th Feb 2015 8:21pm
scwilson
Took this into BLR today who were excellent as per usual. I am in need of 2 new rocker cover gaskets so this is booked in for a few weeks time. It is nothing to do with the gearbox, it's running down from above.
Post #314967 26th Feb 2015 2:13pm
Rovertech
United States
Ask them to change your VC solenoid seals as well. They are probably leaking worse than the cam covers if they haven't been replaced recently.
Post #314982 26th Feb 2015 3:36pm
scwilson
What are those?
Post #314988 26th Feb 2015 4:06pm
Rovertech
United States
Seals that attach to the upper timing covers and go around the variable camshaft control solenoids. They should be relatively cheap.
Post #314990 26th Feb 2015 4:08pm
