![]() | Home > In Car Electronics (L322) > TFT Brightness |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Ive noticed my screen will fluctuate with brightness for example it gets dim if it is extremely cold outside. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
thats normal...the lcd crystals get cold and also they dont get enough voltage so the screen doesnt function properly ....a vehicle re-start will sort it.. ... - .- -.
Yea they actually "warm-up" after a little while and they are back to normal so I typically don't bother with it. |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
I blame the English weather then! |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Mine has a light sensor top right above the phone button. If I cover it up it dims the display, but only if the headlights are on. My Previous RR's!
Cheers Hoppy, I'll check that out. TFT seems to back to normal now and dimming when it should |
...or, go to a car window tinter and get an offcut and place over problem screen........sorted. |
You could be on to something there Stan. Moderators Mods Ltd |
Chillb Member Since: 25 Jul 2012 Location: Portsmouth Posts: 142 ![]() ![]() ![]() |
Checked and mine, 08, does not have a sensor on or near the screen, only the dash lights dim from the wheel. There is in the settings menu a screen brightness and colour change but surely this is cannot be the only way to access while driving. I remember of my old 03 model, the screen and dash lights dimmed from the wheel by the headlights.
Mike, yours does have a sensor ...its number 12 on the diagram..
Oh |
your dimmer wheel should dim it slightly.[as well as your speedo/rev dash bit btw] ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Stan is right on the money |
