![]() | Home > Technical (L322) > Unexplained battery discharge???? |
| Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209
i take it they checked for any battery drains? |
| ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936
Mine got a drain dealer cant trace why I'll live with it gonna fit a aux battery for the Winch |
| JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 269
I guess they checked for drains. They said they'd given it a complete once-over. The ideal solution would be an auxiliary battery. Unfortunately, the LPG kit is where they'd fit it. Is there anything which typically causes a drain? The RAC bloke said a drain could even be something as simple as a lightbulb! |
Sat Nav /tv and Tracker are two i have had |
Good try. It's an HSE and doesn't have either. |
Transport fuse 14 but I guess as its a 2003 theres no danger of that
Oh where have they fitted the LPG bits to get in the way. I'm thinking of the towball storeage area |
You're probably right about the battery. If it wasn't stuffed before, it probably will be now. Good point about the LPG kit. I was thinking the battery would go in the spare wheel well somewhere so that may be an option now. Any more thoughts? |
| jonny142 Member Since: 29 Oct 2008 Location: Sheffield Posts: 28
[quote="JW911"]You're probably right about the battery. If it wasn't stuffed before, it probably will be now. Good point about the LPG kit. I was thinking the battery would go in the spare wheel well somewhere so that may be an option now. Any more thoughts?
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Browsing and came across this
Thanks, Jonny. Sounds like the problem. Will mention the HVAC and TSB to my specialist as well. |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
started having the odd battery issue, always when i least needed it. Pre heater seemed to kill it off
New battery installed on Tuesday after minor gearbox issue (wouldn't change up beyond 2nd in auto - ok in manual). Everything now back to normal or so it would appear. If certain computers aren't getting enough voltage, they reset which can cause a few issues. Watch this space.... |
Just left it parked up for three days and it started first time with no problem whatsoever. Guessing the battery was mullered. |
| All times are GMT |
