Home > Maintenance & Mods (L322) > Removable Tow Bar supply / fitting - Surrey?
NickH72
Hi all,
Need to tow a trailer now and again so looking for the removable swan neck type as i dont want an ugly rear end on display! Live in Leatherhead and work in Weybridge. Any recommendations? without paying main dealer prices of course!
Thanks
Nick
Post #21717 7th Jul 2010 10:32am
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Fit it yourself.
Easy.
Get 1 from here:
http://cgi.ebay.co.uk/Westfalia-Land-Rover...3effbc0c79
Ring them, very helpfull.
Post #21722 7th Jul 2010 11:49am
yawlboy
United Arab Emirates 2009 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
as nbunney said fit it yourself. I fitted mine in about two hours. you will need help though as the kit is heavy.
Post #21731 7th Jul 2010 12:26pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Fitting the bar is simple DIY but the electrics need to be done someone with the diagnostic software so that they can "tell" the car that it has towbar electrics - it will then detect the presence of a trailer via the plug and disable the rear parking sensors and freeze the suspension at normal height.
Post #21733 7th Jul 2010 12:53pm
nbunney
My 2002 RR did not need telling, it recognizes the fact that the Trailer module is installed and when you plug the trailer lights in it notices the change in resistance.
Post #21747 7th Jul 2010 3:04pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Indeed - I thought that all that was done by plugging in the correct wiring loom, rather than diagnostics !
Post #21752 7th Jul 2010 3:42pm
DeltaC
Nigel,
Does the light on your suspension knob light up to indicate its frozen at "standard" when you hook the trailer up?
DC
Post #21756 7th Jul 2010 3:51pm
nbunney
No not seen that, but I did try to lower it and it said I could not, due to trailer.
But then again I was only playing with a trailer board.
Post #21763 7th Jul 2010 4:16pm
DeltaC
Oh well.. I was told by my friendly independent garage owner that it had to be configured. I watched him do it with Autologic. Maybe you can get away with the car recognising that something is plugged into the towbar wiring and it knows the lighting load will change, that the suspension should be inhibited and the rear parking sensors should be disabled....
If you do choose to DIY, I'd recommend testing that it does "all of the above" before you get a surprise when you are tootling along with a laden tandem axle trailer and the car changes height..
Post #21767 7th Jul 2010 4:42pm
NickH72
I would deffo like someone in the know to fit it!.. any suggestions in the SE? Leatherhead, Weybridge ish area?
Post #22401 15th Jul 2010 1:55pm
I have the removable tow hitch and it was fitted by my dealer when I conect up the trailer the green light comes on the parking sensors at the back turn off but I still maintain full control of my suspension . 2008 MY Supercharged
Post #22403 15th Jul 2010 2:43pm
NickH72
Wont the dealers want about a £1k to do this? I was looking at an aftermarket, neat and tidy removable one but fitted by a known/experienced fitter
Post #22404 15th Jul 2010 2:54pm
You bet they will. I was just saying that my dealer fit tow hitch still allows control of the suspension hight . 2008 MY Supercharged
Post #22405 15th Jul 2010 2:59pm
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
I bought my my removable hitch on Ebay for £100 and had Guava in Godalming fit the armature, I saved a few hundred on the full installation. Make sure you get the correct armature for the year of vehicle, they changed in 2006. Contact Guava for a quote. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #22447 15th Jul 2010 8:57pm
NickH72
Back to this one again!
Been quoted £650 for GDW aftermarket system with wiring systems and single socket. Installed. Is that about right? Seems a lot of bloomin money for a tow bar!
Or £824 for the Westfalia LR one. apparently very similar
Cheers
Nick
Post #31622 13th Oct 2010 4:31pm
