![]() | Home > Maintenance & Mods (L322) > Upper tailgate wiring loom |
Just unplug everything, feed the wires out and then refit the new one... Feed your existing loom back through and re-plug it all back in |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
Thanks Craig |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
I had mine changed and painted by a Bodyshop.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
when you pull the loom out is it possible to pull a cord through attached to the old loom to make pulling the new one back through easier? There is nothing that can't be fixed with a hammer😜😜
Two more tips WD... Before refitting, fill it with wax oil |
Stainless steel welding wire is always good |
Thank you sirs, will let you know how I get on |
| All times are GMT |
