![]() | Home > Technical (L322) > Vibration & wheel wobble - RESULT & LESSON LEARNT |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35747 ![]() ![]() |
imperial tyres ? ... - .- -.
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 ![]() ![]() ![]() |
Yeap.
No I'm pretty sure they went metric ages ago ![]() ![]() Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7935 ![]() ![]() ![]() |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
with this sort of fault a typical its a start, is if you try fitting the spare wheel at each corner, till you notice something feeling better etc. however, with two wheels out, you would not have had that benefit.
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 ![]() ![]() |
Hi, always use Hunter system and fully agree with you.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Cold rolling refers to the alloy wheel being rolled in a machine back to true... Nothing to do with the tyre sir |
Thanks C-T-C, caught out by the dreaded syntax again. |
It was the inside edges on both front wheels, probably pot hole damage |
Well done and good news that you have this issue sorted.
