Home > Technical (L322) > air suspension inactive
Shuv.it
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Hi all,
Have recently purchased a range rover vogue '03 plate and it is rather temperamental in the abovementioned subject! All works fine in the sense that no hissing noise nor suspension staying down! Every now n again the air suspension inactive warning raises it's existence for a few days then retreats?! It had a new pump fitted prior to purchase! An independent garage chucked it on the diagnostic machine and it read that it was front driver's side sensor?! Any ideas / suggestions please would be gratefully received!
Cheers!
Post #316404 5th Mar 2015 7:30pm
Do you get any other code? What suggest it is the FR height sensor?
Probably worth taking it off and checking it over, especially the arm and conrod bushes.
That said it might be on its way out! Thumbs Up .
Post #316474 5th Mar 2015 11:44pm
Shuv.it
Hi Joe,
Just the diagnostic said that! The garage r gonna chuck it on a ramp n change the sensor £86 Inc vat n check the wiring also! The bushes have been replaced already!
Will see next week cheers!
Post #316630 6th Mar 2015 9:01pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I've had my front sensor replaced today it finally came up but it's still showing sensor fault and air suspension inactive on the diagnostic hand held any ideas:( _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #316633 6th Mar 2015 9:09pm
Shuv.it
air suspensison inactive
Unless it's the wiring to the sensor? My garage said to us that if the new sensor doesn't clear it then that's the next port of call! Mine has had a new suspension pump fitted November last! And we r experiencing these issues at present!!
Post #316652 6th Mar 2015 10:49pm
Are all the faults being cleared? They not only get stored in the EAS ECU but also in the LCM (light control module).
You could also try a battery disconnect for 30 minutes, touching terminals (not on battery the cables!) whilst disconnected too. .
Post #316658 6th Mar 2015 11:37pm
