![]() | Home > Technical (L322) > coolant |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
silly question maybe but best to check.
Thanks. I bought some antifreeze and topped it up today, it only took about 1/4 pint so maybe its the sensor. I will keep an eye on it. thanks for your help. |
billcyn Member Since: 20 Oct 2013 Location: Whitby Posts: 56 ![]() ![]() ![]() |
Just replaced my coolant header tank c/w sensor after being driven nuts with "check coolant level" bongs.
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
I might be wrong but I am sure (I think) that sounds a bit daft......never mind back to what i think I may be sure about
As northernmonkeyjones said, you need a 50:50 mix of PINK antifreeze & water. This can be checked
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Yes they do Ziggy |
Yes they do Ziggy Thumbs Up
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Why is the color so important? Is blue not good for the RR? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
As I understand it, pink is longlife - 5 years whereas blue is only 2 years. If you mix them it reduces the pink to 2 years.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Pink coolant every four years regardless of mileage. According to wiki. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Depends on the engine chaps.
Yeh don't mix. But my td6 definitely pink. |
Strange that cos both my Bmw 3.0 diesels were blue?
Hmmmm does state in wiki longlife coolent. I always assumed that was the pink oat stuff every five years and blue every two years. But mines definitely pink. |
