![]() | Home > My Range Rover > My £4,600 TD6 Project |
| docjones Member Since: 22 May 2013 Location: Helsinki Posts: 48
Hi Riverstick,
| clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183
any news on the TC project? |
| Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117
Hi Guys,
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
.... Hybrid turbo ?
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
What a great read |
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932
^x2 |
New transmission, torque converter and turbocharger fitted.....Water methanol injection system in the process of fitting...
What a brilliant project.
Hi MJ,
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Have you thought about using an aquamist system for the intercooler?
Hi King,
Cool, I've seen similar systems in the past where they end up dumping the IC and pipework as well as it reduces spoolup/lag so fullboost is achieved much earlier. This would go well with your lower lockup speed you have...
I looked into the BMW compound turbo setup and fitting it is not really a huge issue as the Range Rover engine bay is generous with space. The main issue with this set up is controlling the waste gates and by pass flaps on this system. The Exhaust Manifold Pressure and Boost Pressure must be accurately controlled and balanced, and this is done via the ecu and an array of electro/vacuum solenoids. I failed to find anyone to take on this end of the upgrade so I made do with just upgrading the existing turbo.
With the compound turbo and flaps would it not be best to go manual and old school and have two different wastgate air pressure circuits and mechanical divertor valve as well? This would take care of the boost part of the system.
| All times are GMT |
