![]() | Home > Technical (L322) > Intermittent White Smoke |
| Bobcat4472 Member Since: 17 Feb 2014 Location: Stafford Posts: 8
Help required. Yesterday morning around 9 miles into my 12 mile daily commute to work it looked like the world had come to an end. Behind me was an enormous cloud of white/grey smoke. The smoke dissapaited after a few seconds and I noticed no loss of performance. About two miles later the same again. I took her out for a spin at lunch time and it happened again so I quickly ran it up to my mates garage where the motor ran sweetly for half an hour without incident. He plugged in the computer and found no fault codes. I returned to work untroubled and again there was no repeat on my return home last night or my journey to work this morning.
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
New Pope? |
Paul
| Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420
JJ |
White smoke! They emit white smoke from the Vatican when a new Pope is chosen. |
Nice one.
Sorry,
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Did it chuck out the white smoke shortly after braking??
Thanks for all the suggestions.
Easy way to check, drive along, brake hard for a few seconds, then accelerate hard, if it does it then it's pretty much 100% the servo.... Pete
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Thanks Pete, never heard of that problem so good to store in the old memory banks |
Again thanks for all the helpful advise.
If they forced the pistons back in too fast when changing the pads then they could have flipped the seals in the master cylinder, they could then have flipped themselves back whilst driving, don't know exactly how the FF system works but I suppose some could have got through and into the inlet, it doesn't take much to make a lot of smoke...
Well stone me after going 3 weeks without even a hint of smoke it has returned with avengence. The smoke was so thick this morning that it nearly caused an accident.
| All times are GMT |
