Home > Technical (L322) > no heater blower |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
hi mate the blower motor is the same as bmw one look on flea bay for the bmw one should be about thirty pound have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
10th Mar 2015 12:19pm |
you will find a lot of parts are bmw as they built it like I said look on flea bay for the motor and when replacing make sure the hole is as big as you can get it ,you can cut away the grey foam like thing to give you more room.
10th Mar 2015 1:16pm |
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 |
Thanks. Found one and bought it for £33....a lot cheaper than a RR one on Ebay which all seem to be much more expensive than BMW equivalent. Mad !!
10th Mar 2015 1:25pm |
good stuff the grey bit is I think just a rubberised sealant, I cut mine away and didn't have any problems with it after .
10th Mar 2015 2:10pm |
Hi. I have cut away some of the spongy grey stuff and some of the rigid plastic that faces the grey stuff that can make getting the motor in and out difficult. I used a rotary mini tool, like a dremel, and would recommend these as they cut through the plastic very easily and neatly. You may well need several spare cutting bits as I broke 3 of mine cutting the rigid plastic deep in the hole as all the force was on the far end of the bit. You do need to make sure the cutting bit doesn't go too deep, measure the thickness of the plastic and put a dab of white paint on the cutting bit so you know when you've reached that depth.
11th Mar 2015 11:05am |
The "new" used fan arrived today and now fitted.
12th Mar 2015 8:32pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
Great result! I found mine made a noise at full speed but I fixed it by bending the blades back to shape in situ and it was fine... but that was luck..
14th Mar 2015 12:26pm |
winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 134 |
Im attempting this now, im at the blower motor but cant see clips at the bottom to get the cover off? Just one at the top[/img] |
15th Aug 2015 4:34pm |
You might need to enlarge the hole to see the other fixings.... 2002 4.4 V8 with LPG
17th Aug 2015 11:24am |
Hi
17th Aug 2015 11:30am |
You need to remove the central dash airvent and then the two black plastic curved rectangular section "pipes" that feed that central airvent can be moved out of the way slightly which helps. I kept cutting away the plastic (being very careful about wires and checking there wasn't anything else that would get damaged) until the hole was big enough to lift the motor straight out. Look at the photos earlier in the post to see how big I made it. Cutting the spongy grey bit also helped.
17th Aug 2015 11:41am |
phillh Member Since: 28 Jan 2011 Location: Hertfordshire Posts: 6 |
My son has got an L322, he had a failing blower motor, he has now replaced it thanks to this very helpful guide.
19th Sep 2015 8:16pm |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
Oh 's
7th Dec 2015 2:12pm |
All done and dash refitted working like a dream ... have photos so at some point will make up and guide for the 2009 onward full fats ...not sure when the layout changed might even be a fair bit earlier.
8th Dec 2015 9:47pm |
