![]() | Home > Maintenance & Mods (L322) > [HELP] Odd coolant drops... then they're gone + other leak! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8739 ![]() ![]() ![]() |
^^^^^^What he said ^^^^^^ Pete
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
tx |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
I concur with the above... Looks like the rocker cover gasket |
Thanks Craig.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
have you not discounted the valley pan seal? if you research, you will find that there is a tendancy for the valley seal to leak a bit, and there is an fluis escape path on the left bank. for coolant to run into the bellhousing 'inside' area and drip out on floor, there is a small hole at rear of block, to drain any liquid on the valley between the head and inlet manifold. if you were to dib a small pice of tissue on a long nose pliers etc, towards the rear of the valley you might find that this area is wet. mine is due a valley seal change as has same symptoms.
Thank you John, watched and quite interesting indeed. Wil check for leak there indeed with some paper towel.
I would simply use brake cleaner J |
Merci Craig, somehow reassuring - we have a 1500 miles Adventure planned and I can not afford to break down during the Adventure. |
its possible your valley seal is leaking and the little hole in back of block is blocked, so it overflows, down outside (and inside) of bellhousing. that hole enables water to drain down rear face of block, round the rear seal and down into the bottom of bellhousing. you could remove the bung and put finger in,(engine off!) to see if wetting is there.
Thanks johnboyairey,
Today's update.
Hi gang,
going back to the valley rear bleed hole, (you can see it in your pictures...the tiny pool of liquid, might be coolant, in its boiled down state. ie the water will have boiled off leaving neat greasy coolant? is this being thought of as clean engine oil from rocker covers.?? |
Hi,
