Home > In Car Electronics (L322) > (P) light - query / binnacle reset [SOLVED]
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Hi All,
How long is the (P) light supposed to stay on after the car has been shut down? I have a feeling my resetting binnacle may be caused by the car never going to sleep properly Sad
Just in case anyone else has the same issues :
Park car up for longer than a few hours - binnacle display resets to 'blank' - i.e. Range etc not chosen. Fuel gauge goes up to level, then steps back to empty - then back to level - like some sort of reset/self test. Sometimes get the main beam light come on and then go off.
Battery is a month old, 110Ah.
What's wierd (!) is that I can happily run the FBH for 30 minutes and start the vehicle Whistle Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #310460 4th Feb 2015 10:58am
DMRR
Right ... as no-one offered up a solution I took it on myself to start removing things.
I've sorted the issue and you will not believe the solution ....
ODB port cover removed - issue stops.
ODB port cover replaced - issue arises.
Bluetooth snub Diagnostic apadapter plugged in - issue stops.
So it would appear I have a faulty ODB cover?! I've no idea what it's been shorting Sad Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #317838 13th Mar 2015 1:06pm
its been mentioned that leaving the obd flap open has drained batterys ,but not heard of a flap being faulty... ... - .- -.
Post #317840 13th Mar 2015 1:16pm
DMRR
Hi Stan - not sure how it could (if it was simply not there), I think my faulty one HAS been causing battery drain (I even bought a new battery).
So essentially I'm no worse off with it off or on - apart from the car actually remembering my selections, not 'rebooting' itself and cycling all the dials! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #317842 13th Mar 2015 1:21pm
i havnt looked myself but has the obd flap have contacts on it Neil ?.. ... - .- -.
Post #317844 13th Mar 2015 1:30pm
DMRR
It does indeed, three of them. However none of my other LR's have contacts in the cover. Seems a little odd as the reality is the ODB connector is a standard item ...... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #317849 13th Mar 2015 1:36pm
DMRR
http://www.justanswer.com/uk-car/23bkd-ran...t-two.html
Aha! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #317850 13th Mar 2015 1:39pm
so have i read this correctly, flap off = no drain, flap on = possible drain. ... - .- -.
Post #317857 13th Mar 2015 2:14pm
DMRR
Yup....that's the gist! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #317938 13th Mar 2015 10:06pm
