![]() | Home > Wheels & Tyres > TPM system.........again |
@birdbrian,
no, you will have to fit on FF and drive for at least 15 minutes......saying that , LR diagnostics can re-programme the sensor while its in the spare, but that will cost.. ... - .- -.
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 ![]() ![]() ![]() |
Cheers Stan.
We seemed to have solved the problem. Local indie found spare wheel sensor and / or aerial giving error. From Stans post and other research I'd done I dediced it could be the TPM module in the boot as that also acts as the aerial for the boot. We fitted a borrowed module and problem went away. Now nearly £100 lighter after buying a new one. Fingers crossed........ |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
Are you sure ? I agree that TPMS isn't a requirement on a pre-2012 car. However, I thought if it was fitted, then it has to work - any warning lights are an MOT fail for all cars. |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Think it is because it is not a testable item, so can't failed
I thought that any options fitted had to work - including towing sockets and the like.
That's what I was told by my MOT tester - but he could have been wrong..... |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Sorry I didn't get back to you on the location Birdbrain but see Stan's got there now - all done by the garage anyway so I don't know!
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
I seriously wouldn't fork out any more money on new valves.
elmer Member Since: 24 Mar 2013 Location: Spain Posts: 17 ![]() ![]() |
What iidtool did you bougth?could you cancel the tpms warnings? Thany you |
I had the bluetooth one, but I think they can all disable the TMPS
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I fitted a TPMS system to my ffrr, I'm really happy with it |
Hello,I'm waiting for the final confirmation that I can cancel the TPMS warnings with the IID BT Tool number DA6412 (britpart) to buy in England and I send him to Spain.
YES |
