![]() | Home > Technical (L322) > Can brake discs be out of balance? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
I have had my wheels balanced twice now but it's not making any difference, at certain speeds there's still an element of wrongness there, it's not totally smooth on the motorway, as it should be and used to be.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
You might be able to get the wheels balanced on the car, I'm not too sure what is involved. That way any imbalance in the drive chain will also be dealt with. Stan is probably the best person to answer this |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Check the ball joints as well as these can cause a wobble if worn. There has been discussion about the possibility of hubs being the cause of wobble as well. Worth putting a gauge on the disc and seing if it runs true. There is nothing that can't be fixed with a hammer😜😜
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 ![]() ![]() ![]() |
Have a read of my recent post on this subject and my experiences.......
The friends taking care of my SC had a vibration at higher speed caused by low tyre pressure. All gone now.
It's not a binding brake by any chance?
^ Could be, but I don't think the calipers on the 5.0 suffer the same as those on the 4.2 and tdv8. They changed the rears for different bigger versions on the latter cars. There is nothing that can't be fixed with a hammer😜😜
Dare I suggest alignment... Are tyres wearing evenly worth checking inner and outer edges of tyres as this could be causing effect you describe. Present :2008 TDV8 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
typically wheel balancing problems arise around the 35mph ,50/55mph and 75mph speeds...
Stan I did say that I wasn't too sure |
The link in my post above didn't work - i'll try again, or search for a post titled "Vibration & Wheel Wobble - RESULT and LESSON LEARNT". -
