![]() | Home > Off Topic > garage air compressor - advice requested |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I think it is time for me to upgrade and replace my air compressor. I have had an Aldi compressor for 5-6 years and although it works to a point, It is getting very tired and I think it is struggling to drive my Impact gun.
Thanks, no local machine mart, but can always mail order. Electric shouldn't be a problem as I have the main box in the garage and its 2 cables and 2 meters. 200 amps I guess. Got sparky in at the moment replacing generator hook up so will get him to pop in a 20amp box for the compressor.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Check, check and check again - before you buy!! |
Think I am the unwary. just been looking at SIP catalogue and all the CFM is piston delivery so guess that will probably be what they deliver at zero pressure. Hadn't really looked at the pipe work, but 90% sure the stuff I have at the moment is 1/4bore hose.
I have a 23CFM compressor which is powerful enough to not require any air tank for storage, the only downfall is it runs on a 3 phase motor. However if you live in an older house there is a chance you have 3 phase coming into the building but it will not be connected so worth checking |
This looks like a top piece of kit that should last you forever
Don't forget that so long as the motor is dual voltage you can run a 3phase unit via an inverter which will also remove start-up load spikes. |
47p2 - Screw compressor would be great, that one is in Cornwall |
I personally wouldn't buy SIP, they are made in the far east and in my experience cheaply made and don't last, but that's only my experience |
Just to cheapen this thread |
Always good to know if there are quality issues, they claim to be made in Italy, which gave me a concern on their build quality |
My GF want to go to Aldi, so will see if they have any left and take a look, the one I currently have is an ALDI single cylinder, which has lasted 6 years, was after more air, which maybe the twin cylinder has 56 TDV8 Vogue SE
Great thing about Italian stuff (or was back in the day) is that they tend to switch neutrals instead of lives. Makes live fault finding interesting ![]() If you're just needing more umph to occasionally run an impact wrench you could always simply add a larger receiver after your compressor (gas cylinder ![]() Hmmm - not sure I've explained that very well ![]() ![]() |
