![]() | Home > Technical (L322) > AC auxiliary fan not spinning ANY IDEAS? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8798 ![]() ![]() ![]() |
Sound maybe the bearing on the compressor, you only hear it when the clutch cuts in and out about the right timings you mention... Mines been noisy for over 15,000 miles, keep meaning to sort it......
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
Thanks for the help! |
Pretty sure I read somewhere you can change the front bearing without removing the pump, although I haven't had a look at mine yet, if the pump still works then someone somewhere will be able to change the bearing...
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Searched everywhere and it doesn't appear that the bearing / clutch Is available separately. |
It'll be a standard bearing, just need to get it out and it and measure it....
Ahhh the old look up the bearing number. |
Yes thanks Greg, new hip is great, on list for other one now, main problem is knee, now totally gone, won't lock straight, can't bend it past 30degrees... so it totally prevents me from getting my teeth stuck into the bigger Jobs on the FF... so just playing at the moment... got lots of big lumps of steel in the garage awaiting playing!!!! They can't do the knee until after the hip so a few more months to wait... Pete
Bl |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
"Steve Austin, astronaut. A man barely alive." "Gentlemen, we can rebuild him. We have the technology. We have the capability to make the world's first bionic man. Steve Austin will be that man. Better than he was before. Better...stronger...faster."
Just back to some sort of normality would do..... Pete
