![]() | Home > Maintenance & Mods (L322) > Removing Land Rover Badge |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
talked about many times rad and there are many suggestions..no holes are left and the way i did it was to heat up the adhesive with a hairdryer and gently prise off the badge..you'll be left with the adhesive on the bodywork which you can rub of with your fingers.. ... - .- -.
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Thanks for the quick response.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Dental floss 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
nylon guitar string. V8 facelift Range Rover Autobiography 22" wheels.
Just an update:
G-string |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 193 ![]() ![]() ![]() |
I'm replacing a knackered badge on mine - will the residual glue be sticky enough or do I need more glue - and if so, what type? 17 MY Corris Grey 4.4 VAB
Best use 3m double sided automotive tape the thinner the better and is what they use in the first place |
Cheers. |
