![]() | Home > Maintenance & Mods (L322) > Key hole!! |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
The cap on the front part of the drivers door handle pops off. Key hole underneath My Previous RR's!
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
Now I feel like a muppet!!!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Your 07 should have a normal keyhole in the drivers door. In the handle cover kit you get 4 blank covers and one keyhole cover. Whoever put the handle covers on put the 4 blank covers on (covering the drivers door lock) so... If it were me i would try to carefully remove the drivers one and make sure when you refit it you only put a small amount of double sided tape on it so if you need to remove it without tools, in the middle of a cinema carpark at midnight etc you know you can |
That makes sense!
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I would also make sure that the key actually works the lock before you actually need to use it. There is a difference between knowing your sh!t and knowing you're sh!t
