![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
Good on you Pete. It really isn't that difficult although to be honest the ones I did were years ago in the days of 3 speeds and brake bands rather than clutch packs. But having read RRPHIL's thread about tearing down the 6HP26 I would definitely have a go.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8735 ![]() ![]() ![]() |
Thanks chaps.
I must admit to having the same feelings really, I bought the rad above mainly because it was reduced to £20 and I couldn't resist the bargain!!!!
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1021 ![]() ![]() |
Pete,
Cheers Phil, had read about the problems with not getting the TC back on right, measuring should sort it... thanks for the tips about the screws....
No - just undo the 9 bolts and pull.
Started the strip out mid morning Thursday, get FF on ramp, leave key in the ignition but switch off, wait 10mins then disconnect battery so the electronic steering lock is free...
Well done so far Pete.
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Really enjoying this topic.
RRPhil, will get the valve body sent off tomorrow, cheers....
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 ![]() ![]() ![]() |
Brilliant read as ever.
Good luck with that Pete. |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
Brilliant thread! Good luck Haylands |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
This is a great, informative thread. Blow by blow with 'Dr. Phil' keeping a beady eye on proceedings. Keep it up |
