Home > Technical (L322) > Hard Ride?
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Hard Ride?
Hi Folks.
My 2009 3.6 V8 seems to be quite a hard ride and I feel every bump. Is this normal
or has anyone any ideas what could be the problem?
Post #318983 21st Mar 2015 8:12pm
Any faults on dash?
Does she visually look like she's sat at the normal ride height?
Does the suspension go up & down as it should via the control buttons?
Post #319009 21st Mar 2015 11:12pm
Garyfax
Everything appears normal, everything
Works as it should. Maybe it's just
me?
Post #319025 22nd Mar 2015 6:45am
What size wheels are you running?? Pete
Post #319035 22nd Mar 2015 10:20am
I'll be watching this with interest as mine is the same.
No faults, freshly serviced and MOT'd with nothing wrong
However, I do know my tyre pressures are on the high side and I've not adjusted them yet. Tyre wear, however, is perfectly even.
It wasn't until a friend commented about the ride that I started noticing it. Si. <This is my name.
Post #319043 22nd Mar 2015 11:02am
As above, check the tyre pressures and if it bothers you and you are running on 20" then try some 19" as the ride is slightly better.
Mine has also never been a magic carpet, and is definitely better on the 19". Today's job is to put the 20s back on now it's warming up. There is nothing that can't be fixed with a hammer😜😜
Post #319046 22nd Mar 2015 11:29am
Hard ride! Laughing
I have a BMW 320d Touring with run flats in stock and its like having no suspension at all.... (Bang, Bang..)
Post #319048 22nd Mar 2015 11:36am
Garyfax
Yes the wheels I have are 20", I will check, tyre pressures. What would you recommend to put in them, its usually
just me or the wife in the car and very rare that I have any weight in it? Thanks for your advice.
Gary.
Post #319049 22nd Mar 2015 11:44am
32-36psi Thumbs Up
Post #319080 22nd Mar 2015 6:19pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Mine has 20's and the drive is very comfy. I can literally take speed humps without slowing down. I believe the original principle was that the range rover should be driveable over a ploughed field at 70mph. Suppose a lot will depend on what you came out of/ perspective. Bmw m sport or rolls Royce phantom? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #319116 22nd Mar 2015 10:09pm
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Garry hi
Felt the same when I went from my D3 to my 2008 3.6TDV8, in fact the dealer has it in now after 14 weeks, correcting problems and we were given a Discovery 4. All have noticed, as hard as it s to say, the D4 is less 'bobby' on slower uneven roads ie local driving. I almost felt the suspension was lowered which tends to fell like this. I run the standard 19's.
Not sure how true this is but a friend of mine (BMW Motorsport tuner) said the struts / springs (can't remember which) on the Ford FFRR's were stiffened up a bit over the original BMW designed FFRR's. Don't quote me on that though.
On the motorway and smooth roads the FFRR is beautiful, I must admit the D4 does go round bends with far less body roll. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #319118 22nd Mar 2015 10:22pm
I find my D4 will corner slightly better than the FFRR, lets not forget though it is basically a more practical RRS. There is nothing that can't be fixed with a hammer😜😜
Post #319119 22nd Mar 2015 10:26pm
Garyfax
Thanks for the advice folks.
Checked tyre pressures and the back
ones were at 42 and front 36.
Dropped em all to 34 and problem solved.
Different drive.
Cheers
Post #319173 23rd Mar 2015 10:33am
Thumbs Up Thumbs Up Thumbs Up
Post #319176 23rd Mar 2015 10:44am
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Mine was like this and was down to worn suspension bushes, changing them to new ones made the world of difference Thumbs Up
Post #319385 24th Mar 2015 11:24am
