![]() | Home > Technical (L322) > 4.4 derived from the 3.6? |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613
Was there a question there?
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Yes you are quite correct they are... And yes they run a parallel sequential turbo setup apposed to the conventional twin setup on the 3.6... Less lag (everyones complaint when the 3.6 was released! |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
So all 4.4 should really have SDV8 on the back....(they don't) |
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
There was no SDV8 L322, all are TDV8, may they be 3.6L or 4.4L
^ Yes I(we) know that but if the Turbo set up changed on the 4.4 L322 should they not have been branded SDV8 to show the difference ? |
Turbos set up changed from 3.6L to 4.4L, but not since, 3.6L had a single set up, 4.4L one only also.
| VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 413
LR says that the 3.6 and 2.7 are the same.
