![]() | Home > Maintenance & Mods (L322) > Pray for me please |
My money would be on a ball joint. I had this set of symptoms on an old Rover SD1 and it was the lower arms. Not worn enough to show with a pry bar but rattling like a can of nails when cornering. Hellish vibration through the wheels too.
Back in the day I would have removed a half shaft and rear prop and stuck the centre difflock in - that would tell you if it was the rear diff!!! Land Rover Addict
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
How do you stand if he's wrong? John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
@ Weegie.
HalifaxMark Member Since: 03 Feb 2015 Location: Halifax and / or Civray France Posts: 14 ![]() ![]() ![]() |
I didn't ask ! I thought about it - a lot.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I have a very similar issue with my tdv8. On fast slight left handers the whole car shakes like hell, scared my brother to death when he drove it. Lower arm has been replaced and all tyres and wheels changed but problem still exists. |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Its fair to say that GO have always played fair with me....They've given loads of advice FOC and seem genuine.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Jeez, I had the exact same symptoms & it was a dicky caliper. |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Is it possible to disconnect the rear diff and drive on the front axle to rule out the diff.Am not sure it is but am sure someone will know.Certainly does not sound like diff to me,it could be anything.What about the props or the transfer box or an electronic fault.Anyone got a 4 wheel rolling road you could put it on!! |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
It still sounds to me not diff related, if the diff was locked up because the electronic locker has failed then its still not going the cause the wheels to wobble, the inside (of the corner) tire can skip and chirp on hard tight corners
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Hmmm. while the car is waiting for the back-ordered diff, has the garage got another car in, that he could just disprove the 'dodgy wheel' theory, and swap wheels set from another car, and retest ???
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 ![]() ![]() ![]() |
PM sent. Its impossible that the diff can cause the symptoms you describe. Don't spend a penny until you've had wheels balanced on a "Hunter GSP9700 Road Force balance & measurement" machine.
Thanks Guys, I have spoken to GO and asked them to change all the Discs first and balance the wheels again before the Diff arrives from LR ( on backorder until 20th April ). The discs were on their way out anyway so at least that's money well spent. Will keep you informed. |
it seems that there's a lot of money being spent! |
