![]() | Home > Maintenance & Mods (L322) > Odd noise No 2 for today |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
When I am driving at low to medium speeds in normal ride height I can hear a noise which sounds like "pink - pink" and it occurs with slight suspension movements, over small bumps, lumps etc. It is most noticable at low speed.
Did it happen before you changed the discs/pads? Used to have this happen on my D1 when I didn't use OE parts, bloody pads would move around and 'tink' .... Land Rover Addict
I can't remember exactly when it started.
Thinking about this, if it were the pads surely they'd make those noise all the time in all suspension heights, it's only in normal ride height. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
could be the abs sensor being loose...makes noise in standard but when stretched or compressed (off road & access) then no noise... ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Ball joint gone dry! You stretch them in other suspension modes and they shut up!
Craig,
The thing is, it's not a metallic knocking, clunking, clinking sound, it's a 'Pink' noise, almost like a stretchy squeaky noise. Discovery 4 HSE
That's the usual noise Adam. Turns into a harsh graunching noise as it gets drier...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
get someone to rock the steering wheel slightly and look at the suspension from under the front end of the car, you can clearly see all of the front ball joints. with the steering being rocked you may be able to see play in one of the joints and the knuckle moves. As Craig said there are a few to look at. I would start with the lower suspension arm (short one at front) where it joins the knuckle, thats the one which went first on mine. There is nothing that can't be fixed with a hammer😜😜
