![]() | Home > Technical (L322) > urgent help needed - stuck in park |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1416 ![]() ![]() |
not having a very good time with the vehicle at the moment
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Try a battery reset first. Link is in the Wiki.
hi Paul - tried that and still the same - also tried a 'hard reset' of the battery leads - no joy still stuck in park. |
Fuses?
checked fuse 5 and 33 - both associated with transmission - both okay
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
You should be able to feel a quiet thunk when you press the brake (through your hand if it's on the gear lever). It makes a small pin pop out allowing the gear leaver to move and you can hear/ feel it in the lever. It's there so you can't put it in gear without your foot on the brake. You can see the pin if you pull the gear leaver surround up. My Previous RR's!
pulled off the gear gaiter and observed the solenoid , the pin doesn't release when pushing brake pedal and trying to change from park , the pin does detract once the car is switched off , so it is going in and out .
Just a thought, I take it your brake lights are working? If it isn't sensing the brake pedal press? My Previous RR's!
fitted both the parts and now can select gears okay , so the car is drivable , but my hdc , abs ,loss of traction control and suspension lowering remains |
+1..^^
yes - reset all faults - bongs straight back in on starting the engine up
.mm |
