![]() | Home > In Car Electronics (L322) > Main dealer batteries? |
I fitted one of these to my TDV8. If you use the FBH it's a godsend being GEL based. It can start the car when 80% discharged and it will stand a lot of deep dishcharge cycles. Same price as LR quoting.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I think varta is fitted by land rover as standard AGM was fitted post 2009 I think |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
To a certain extent a battery is a battery. Internal components effect the lifespan, R&D contributes to safety, longevity and lifesian. Your looking at two main things the amps per hour (Ah) and the cold cranking amps (CCA). As a rule of thumb the higher the number the more power. You need high cranking amps for the FF and enough Ah to ensure it won't flatten quickly.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Yes but the 110ah battery is a "difficult fit" in some tdv8s, I had to cut the bottom flange off mine which I would imagine has invalidated the warranty! |
Good point NM but do you really expect any problems? Besides fitting stuff with hammers is mandatory on most DIY projects regardless |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
I was quoted about £300 to fit a battery from dealer. I presume a 90ah one. But I sourced one for around £160. It being a varta with 110 ah. Unsure of cranking. May buy one, as the kids tv goes off after a VERY SHORT TIME after the ignition is switch off. |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
I got the md battery was 171 plus vat and is the dogs, popped the bonnet struts off lifted old out and put the new in five mins job 👍
I'll have another word with them to check price again. |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
Can't believe some of these crazy prices |
