Home > Technical (L322) > Battery Disconnect Unit 1 Fault code (& SRS airbag warni |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Rather than just clear the fault code would it not be an idea to get it read so that you then have an indication where the fault lies?
1st Apr 2015 8:51am |
Jcsh Member Since: 27 Jul 2011 Location: Poitiers Posts: 29 |
The fault code was "battery disconnect Unit 1"
1st Apr 2015 10:51am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Bit of googling for you came up with this :
1st Apr 2015 10:56am |
Hey, yes thanks for that. I googled that too and tried it. It just keeps getting reset and nought else. |
1st Apr 2015 11:29am |
Could be a new battery disconnect unit needed
1st Apr 2015 3:20pm |
Or it might be something the other end. I'd like to loop out the battery disconnect unit, so does anyone know how? Does the BDU present a resistance to its Ecu or is it just closed/open circuit? Last night I tried a link providing a short circuit to the Ecu by disconnecting the yellow plug and shorting the wires. Which did not change anything in terms of the light cycling from off to on as soon as the startup diagnostics are performed. |
1st Apr 2015 7:49pm |
This is from the vehicle wiring diagram, seems to be a resistor involved for monitoring.
1st Apr 2015 8:13pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2027 |
my car......... 2002 v8 vogue.
1st Apr 2015 8:24pm |
oh, and I just searched as I thought I had typed this before, and yes, this SRS ECU fixed another members car too. here: http://www.fullfatrr.com/forum/topic17641-30.html |
1st Apr 2015 8:35pm |
Thanks for your help guys, I'm pretty sure that I must have disturbed the ECU connector in the centre console when I was searching for the telephone cabling. I wonder if the SRS 'fault' I now have has turned off the airbags or whether the build can just be disabled safely... I wonder how easy it is to disable the bulb! |
6th Apr 2015 9:49pm |
