![]() | Home > Technical (L322) > Issues after Torque Converter replacement[Verdict added] |
| Shogo Member Since: 01 Jan 2015 Location: Sweden Posts: 61
This will be expensive I suspect..
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
When i rebuilt my transmission i replaced the cooler and the pipes to be safe, mine is an 04 4.4.
I only changed mine so I knew the complete system was replaced. They are unlikely to fail, my concern was they may have been blocked with sludge but if you are flushing you should be fine.
Yes.. everything will be removed and cleaned. A bit worried about the snap-on connections. But they they might be able to replace just the tube and connectors on the original pipes. |
My pipes were stuck fast onto the cooler as they are like you say the push fit connections, but they may be able to shift them. i had just stripped and rebuilt the entire transmission with bearing and plates and all sorts so i thought i dont want to be back in here for a long time so changed it all, well my credit card did..........
So Iīve gotten the car back now.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Glad it's sorted for you, thanks for posting the outcome..
Yes I hope so.
Vibration could be torque converter but it should be locked up fully at around that speed.
Naw.. Itīs more of a driveline vibration(slower). Nothing Iīm going to worry about right now |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Check your brake disc temperatures to see if they are similar all round after a short run. John
Issues with vibrations seems to have been tire related as itīs gone after switching to Michelin Latitude Sports.
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3281
Shogo,
Itīs at a garage, they only replace with OEM or equivalent parts.
