![]() | Home > Maintenance & Mods (L322) > Air suspension inactive |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
It happened to me when I had the air pump out and when I replaced no light at all,i was fortunate as my mate is a wizard with diagnostics and he had it working before I had made him a cuppa.I do not know if there is a way of reseting it without plugging in.I believe there is a small gadget you can buy at around £3o that resets most air suspension faults which is worth a try before you spend good money on a diagnostics guy!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8776 ![]() ![]() ![]() |
Whatever fault it has, has locked the suspension to help prevent it dropping and not rising again, it will be a hard fault and will only reset with a diagnostic tool....
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 ![]() ![]() ![]() |
Thanks for the replys it was reset by an indy and all is good |
Very easy to use, they do two types, one that works with the cruise buttons and gives readout in the dash display (you need a good display with all the pixels working) or the Bluetooth one that uses an app on your phone, both do virtually the same....
