![]() | Home > Off Topic > Any plumbers? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I'm looking to install a shower pump and I've seen one at a good price (£80) which is 1.5 bar rated. The shower that we have currently just runs off the mains water system and is not very powerful. Would this pump be adequate or do I need to go higher?
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
If your shower is fed directly from the mains via a condensing boiler then no the pump you have highlighted will not be suitable.
No, our system isn't a condensing one. It's a hot water cylinder with a tank up in the loft as you stated. It's just not that powerful. |
It's already almost touching the apex inside the loft. I could go about a foot higher but that's it.
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Upgrade your cylinder to an unvented system. Then you'll have mains pressure hot water. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Thats what I've got, bloody brilliant system. |
£400 for a new cylinder v £80 for a pump |
