![]() | Home > Maintenance & Mods (L322) > 4 mpg on the onboard constant mpg display?? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
something wrong with the brakes..any heat from them after a run? ... - .- -.
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
Sweepstake time !
| marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141
Hi Stan, the last few days have only done a 2 mile run each day and no heat in any of the discs or abnormal brake dust on wheels. I am worried that a long run could end up frying discs/pads/caliper seals/calipers or worse putting undue strees on the engine.
if you can jack up each wheel and see if you can turn it easily, make sure its in neutral with engine off. ... - .- -.
Will jack it up in the morning but will have to use my trolley jack as the handle snapped on the LR one last week when the new wheels went on |
| markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316
Tug RR Took the word's out my mouth. I felt some heat coming from the ROS disc earlier this week so decided it was time to get the new callipers built up and fitted. Done both sides to be safe. Handy that having a shelf full of goodies from previous owner need to get the new handles fitted soon |
Thanks for the advice, will get it jacked up in the morning. I have a RAC warranty with the car......does anyone know if it would cover a brake failure like this?
Unsure of RAC warranties etc. Also check for excessive brake dust on the rear wheels. I would certainly say a new calliper will see it right ( £70 euro car parts ) . would advise to change both rears as it only a matter of time before the other side goes. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
Have now used two full tanks of fuel, sadly the consumption is putting me at 10.9 mpg. If not mentioned before all levels (enginge) are fine with no untoward smoke/overheating etc. It takes about 10 mins or so to get to temperature with the gauge dead level pointing to the sky. I also put it into my local indy to check for binding of brakes as suggested and they reported free running on all corners. The only change to the car since purchase on the drive train side is the larger wheels, but to drop 7 mpg from normal on eagle f1's seems daft to me.
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
Could be a lambda sensor on its way out or MAF. Not sure if these would give and engine management light 56 TDV8 Vogue SE
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
If it's just had new brake pads front and rear, then you would think who ever fitted them would have noticed a seized caliper?
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
I reckon MAF. It will over fuel to compensate and will show EML for rich running. Hence lower MPG. |
Hi, thanks for the replies guy's. I have not checked the tyre pressures but will in the morning. It is not showing any faults on the speedo binacle, what does EML stand for and do i need to take it to my MD for a diagnosis of this possible maf problem on their fault reader?
EML = Engine malfunction lamp. |
| All times are GMT |
