Home > Technical (L322) > Cleaning the inhibitor switch?
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
As I'm having problems with the gearbox going into "trans fail safe" I'm going to remove the inhibitor switch & give it a clean as I've read that can sometimes sort the issue.
Do I need to disconnect the battery before doing any work & if so why? Never have on any other car.
Also what is the procedure for cleaning the switch?
Also had the "trans lowbox neutral message" & "trans overheat" yesterday when I tried to use on a small run. 2004 RR 4.4 V8 Autobiography
Post #321238 4th Apr 2015 4:45pm
as long as the FF is asleep and there's no power going to the switch then i dont think a battery disconnection is needed... ... - .- -.
Post #321247 4th Apr 2015 8:58pm
