![]() | Home > Technical (L322) > Reduced engine performance but everything seems fine ? |
| markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316
Also it's low on fuel at the moment around 60 miles left so don't know if that could be the cause ? Crud at the bottom of the tank ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i seem to remember that this kind of problem arises if you hav less than 1/4 tank of fuel, fuel pump?
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
It could still be a dodgy cell I'd disconnect the battery for a while & see if that resolves it. Next step get the battery tested and/or read the fault codes. |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
If you have a voltage meter, just check the battery voltage when running and when not running. If the battery or alternator are not in good shape, the voltage may be dropping and generate the usual random faults.
Thanks guys.
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
Mark - I'll drop you a PM with a pointer
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1417
get some |
It's top of my to do list so fingers crossed that's all it is. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
Filled up today. Done around 30 miles. So far so good |
