Home > Technical (L322) > 2012 Front Brakes |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
The naturally aspirated 5.0 has the 3.0 D4/RRS 2-piston calipers. |
7th Apr 2015 12:33am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
When Land Rover brought out the last major upgrade to the Range Rover with the TFT screen the 3.6 TDV8 ( and apparently the 5L N/A ) were " down graded"to the sliding calliper brakes but the new SC 5L was given the six pot Brembo's ,then a year later when he 4.4 TDV8 came out with the 8 speed "box" Land Rover could announce a brake upgrade across the range . Bad call but good marketing . 2008 MY Supercharged
7th Apr 2015 3:09am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
As above
7th Apr 2015 9:22am |
Microcat shows the 2-pot calipers for all 2010-2012 with na 5.0 engines.
7th Apr 2015 9:54am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Ask Mick (Joker) about this rather touchy subject! Got - 2017 SDV8 Autobiography in Loire Blue
7th Apr 2015 10:00am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
My Dad's 2010 3.6 TDV8 VSE has the rubbish brakes. They are SO different in use to the Brembo ones I am used to on mine. Scary Discovery 4 HSE
7th Apr 2015 10:05am |
That'll be the 2012my which was released in 2011 sir |
7th Apr 2015 10:09am |
MY12 still built up to about the end of June 2012 with some sold here until at least the end of 2012. Hence the OP's observations are not unexpected. |
7th Apr 2015 10:14am |
7th Apr 2015 10:17am |
Copied from Wikipedia
7th Apr 2015 10:21am |
The 4.4 TDV8 was available in a Sept 2010 built MY11 eg SALLMAMH3BA336273 yet my supplied VIN above is for an August 2011 built MY12 na 5.0 without Brembos, as observed from pictures that are supposed to be of the same vehicle as the VIN. Hence I can't see how "Brembos across the range" can coincide with the release of the 4.4 TDV8 unless in practice the UK did not get the na 5.0. |
7th Apr 2015 10:50am |
I wonder how the 2010 3.6's braking compares with the D4's use of the same caliper. I note that the pads have different part numbers and do not know if they use the same size disk - certainly not the same part numbers. However with not that much difference in vehicle weights I expected pretty much the same result. I was considering fitting the lesser calipers if I needed to fit Compomotive 18" rims for better off-road tyres, having been happy with the 2.7 brakes I fitted to the D4 to allow 17" rims to be used. |
7th Apr 2015 11:01am |
bpp1980 Member Since: 21 Apr 2013 Location: Melbourne, Australia Posts: 30 |
Crispy, thanks for opening the discussion on this topic. Looking at upgrading from a 3.6TDV8 to a later model 322 (SWMBO has a distinct preference for the "boxy shaped range rovers". Towing our caravan, which weighs in at about 3.1T fully laden, I am super impressed by the TDV8, so while e heart says SC, the mind says TDV8. So... Looking at late model 322 4.4's. Towing a decent weight van, looking to make sure the tug has adequate stopping power! Pi wasn't aware the TDV8 had lost the brembo a at some point, so keeping a watchful eye on this one. |
7th Apr 2015 12:29pm |
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 |
No probs BP, thanks to others above for input. Will look out for this one day when SC upgrade required.
7th Apr 2015 2:37pm |
