Home > Maintenance & Mods (L322) > 2002 Brake Shoes mod
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I thought I'd share this fix to repair the rear brake shoe retainers.
The brake retaining pins on the rear brake shoes in time will pull through the back plate of the brakes, I've had this twice now and when they fall out they make a sound that sounds like the wheel bearings have failed.
I've modified mine by using retaining pins that push in from behind the plate and retain inside the brake assembly, the parts I used were from a Ford Cortina, the new pins are slightly to long but I packed them out from behind the brake back plate with an M8 nut.
The old (broken) and new retaining pins.
The new pin in place retained on the inside of the brake disc.
The original pin type.
Post #320002 27th Mar 2015 12:00pm
I think I might have to do mine, heard a noise when I reversed into the garage the other day.
Do you know what length the Cortina pins are and where did you get them please?
Post #320036 27th Mar 2015 2:45pm
Richcl
They're approx 25mm long, if you went to your local motor factors they may have them from another make of car the correct length.
I used Cortina ones as I remember how the fixings worked, I got these off ebay they were listed as Mk1 Cortina.
Post #320046 27th Mar 2015 3:05pm
Thanks, do you have a link to the eBay advert please?
Post #320094 27th Mar 2015 8:33pm
Richcl
http://www.ebay.co.uk/itm/231491078014?_tr...EBIDX%3AIT
Post #320106 27th Mar 2015 9:14pm
Thanks, that's the one I sent a message asking the length of the pins and the reply was
Quote:
Hi there,
The pins are just shy of 37mm.
Kind regards,
Barrie
so looking for something around 33-34mm
Post #320128 27th Mar 2015 11:28pm
Just spent a couple of hours on my handbrake, one pin had fell off and was caught between the disc and backplate which was the source of the noise. I managed to shape a washer for the rear of the backplate and refitted the pin so all is well for another while
Post #321682 7th Apr 2015 8:57pm
Excellent idea, I just bought two new backplates for mine as, although the pins are still holding, they have massive rust holes in them letting in all sorts of crap to mess up the shoes...
They are about £40 each + VAT for your info.... Pete
-Click here for Thread-
Post #321691 7th Apr 2015 9:30pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Great mod lads.
thank you, as my shoes decided they were coming off with the disc.
corrosion on offside rear but backplate on nearside looks quite new.
cheers Thumbs Up
Post #321724 8th Apr 2015 7:52am
And a complete PITA to fit!!! Rolling Eyes
Big strip down required Pete! Whistle
Post #321740 8th Apr 2015 9:10am
Great find sir Bow down ingenious Thumbs Up
Post #321741 8th Apr 2015 9:11am
Craig...
I have to change one rear driveshaft and also all the rear brake pipes and flexis... didn't look too bad, apart from the driveshaft nut (any idea what size it is as you need a 12 point socket??) what bit is the PITA to do...????? Pete
Post #321768 8th Apr 2015 1:50pm
Decided to do this mod slightly different to Richcl
I kept and used my original pins/springs and just put a brake shoe hold down washer at the back of the backplate
These are available on the bay of fleas for less than a couple of your hard earned pounds
These washers come in two different varieties, Lockheed or Girling and I haven't a clue what the difference is, but I bought the Lockheed ones and they fit perfectly
Post #322596 14th Apr 2015 5:02pm
