![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
It's looking that way..... |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1012 ![]() ![]() |
It's certainly very disappointing what you've found up to now. The whole transmission sounds, to put it kindly, very tired - and the cowboys that previously rebuilt it haven't helped.
Cheers Phil, I'll have a look round....
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
Hi
Thanks for your kind offer, I'll have a good look around and see whats on offer.... that LHD one was at a local place and it's gone now so still looking.... Pete
RRPhil, I've sent you a PM.... Pete
You could still buy my 2003 FFRR V8 |
Yes, as heppsen has already stated, there’s no difference between LHD & RHD models as far as the transmission is concerned. On the ‘032’ Range Rover model both the selector lever and the inhibitor switch are on the RH side of the transmission. On the BMW X5 (‘029’ & ‘034’ models for the 4.4i and 4.6iS respectively) the inhibitor switch is on the RH side but the selector lever is on the LH side. Other BMW models with the 5HP24 have both the lever and the switch on the LH side.
Cheers Phil and heppsen, thought I'd read somewhere they were different....
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Good luck Pete - Looks a decent box. |
Cheers, the filter is dated June 2014 so not been in long....
Hmm, that is a bit higher than usual. EPRS1 is the ‘green cap’ main pressure solenoid and its winding resistance is usually around 0.5 ohm lower than the four other ‘black cap’ EPRS solenoids.
Pete,
Cheers Phil, they all measured at the top of their range, it could be a low battery in my meter.....
