![]() | Home > In Car Electronics (L322) > TV in motion and video on a 2003 Non Touch Screen, Questions |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi Chaps, I've just fitted a new toy to the tank and it has thrown up and couple of problems that I'm hoping someone will have the answer to |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8045 ![]() ![]() ![]() |
This is the one I had - it also has a reverse camera input - I wired to the reverse light to auto switch over to it.
Did this give you the ability to see the camera when you are moving? Yesterday I couldn't spell Engineer... Today I are one!
It has 2 inputs -
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7937 ![]() ![]() ![]() |
Hi mate.
Is there a way to feed a camera into the existing setup ?
Alistair, yes you can feed a camera in to the existing system, via the white plug on the TV tuner. However you will also need TV in motion so that you can access the camera when moving. This is locked out at the factory, and has to either be unlocked by Navcoder ,thanks Mark, or by buying a patch lead that goes in to the blue plug on the tuner. This lead is over £50 |
Mark, forgot to ask, is your Navcoder interface permanently wired up, or is it removable? Yesterday I couldn't spell Engineer... Today I are one!
I bought an interface from bmw cables and it has a USB on one end for the laptop and the other goes in the obd2 port under the dash......
Ooooooooo |
Update
